Hi. I wanted to turn of easy exit, that went well but caused some issues. I reverted afterwards to easy exit to not present and ran the proxi alignment all over. Things got better overall but Engine still flashes an error U1713-2F. Proxi alignment tells me everything is all good, but the error is persistent.
Any tips how to remove this?
Giulia error after proxi alignment - U1713-2F - Engine control (NCM)
kostergaard
keverlever
Re: Giulia error after proxi alignment - U1713-2F - Engine control (NCM)
I have currently the exact same problem.
Did you find a solution?
thank!!
thank!!
I have got the same problem on my Giulia (2016 Super 2.2 TD). Previously I had MES version 4.8 and I had to carry out a previous canbus alignment after installing an android unit, all went well. I have recently upgraded my MES from 4.8 to the latest 5.3 and now when I run I canbus alignment I get the fault code which will not clear. I have managed to get rid of the engine light now by disconnecting the battery but I was going to reinstall the old 4.8 version but the licence I now have wont let me
