seattleabarth
2013' USA 500 Abarth - with 18' 595 TFT proxy align
Post by seattleabarth »
Anybody got proxy align to work correctly for a retro TFT? i have a USA A500 Abarth multiAir. 2013. And put in a 18' TFT from a UK 595. I can get the logo, but if i proxy align. it resets the TFT logo from the Abarth to normal 500. as well as backup sensor (13' doesn't have one).
so looking for a proxy align that works with the one below with DRL off.
Looking for
- successfull proxy align
- with Abarth Logo
-- ideally backup sensor off.
7/17/2022
Abarth Logo: - Original
31 35 31 35 36 39 38 33 32 30 30 31 32 33 34 35 36 37 38 39 30 20 14 10 15 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 80 E0 4D 06 F4 40 01 75 BA 15 08 67 01 09 00 94 0A 12 02 1E 01 30 30 70 00 00 00 00 00 00 00 00 27 00 00 00 00 31 06 B1 01 80 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 01 94 28 52 00 04 88 02 00 20 80 68 00 40 00 81 00 0F 00 00 00 80 85 80 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10/16/2022 - backup working logo, DRL off.
31 35 31 35 36 39 38 33 32 30 30 31 32 33 34 35 36 37 38 39 30 20 14 10 15 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 80 E1 0D 06 F4 40 01 75 BA 15 08 67 01 09 00 94 0A 12 02 0A 01 30 30 70 00 00 00 00 00 00 00 00 27 00 00 00 00 31 06 B1 01 80 00 62 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 01 94 28 D2 31 04 88 02 00 20 80 68 00 40 00 8B 00 0F 00 00 24 80 85 80 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 01 00 00 00 00 00 00
Koen001
Post by Koen001 »
I am new on the platform, hope you guys can help !
I purchased a 2nd hand Fiat 500 S Model 2017 that has a 7-Inch Uconnect device however Carplay seems not being enabled on that version.
Seeing other members having similar problems with this I was wondering if I would be able to get CarPlay enabled on the Uconnect I have ?
I am not an expert in coding but could have my local car maintenance guy to help me of course.
If some of you know how this could be potentially fixed I would appreciate this, in that case a step by step procedure would be welcome as I am not an expert.
Many thanks in advance,
Koen
Slayaz
Post by Slayaz »
HELP! I've just broken my car....
ALl i was trying to do was acrivate carplay!
I ffel sick
naibaf91
Post by naibaf91 »
Did you save the old proxy file? If not, only the workshop can help.
Slayaz
Post by Slayaz »
luckily a guy from the UK Abarth group has kindly come to the rescue, I had drained the battery so needed a jump start before he could even access the ECU..
He's managed to reset to factory reset and is now clearing all errors and undoing my almighty f**kup.
He said he'll also turn on CarPlay, so that may be a positive.
Rockthat500L
Post by Rockthat500L »
chrener wrote: 02 Jun 2023, 09:40 I had the same issue in airbag node and when i looked to FESlog after proxialignment, node asks for change byte 69 i f remember right.
After byte value change passenger seatbelt reminder still runs alarm also with empty passenger seat... Of cousre after seatbelt lock it was OK...
I solve it with unpluged seat nonnector and then proxialignment done with success with original airbag node settings...
EDIT:
As i see in your proxi - you have 69=0C, try to aligned with 69=04
Hi chrener. How do i activate uconnect live-eco drive on my 500L? Also how do you know what byte changes what function from the bytes? Is there a place i can learn the corresponding functions for the bytes? Thank you.
chrener
Post by chrener »
Rockthat500L wrote: 06 Oct 2023, 09:17
EDIT:
Try 139=80
Yassyeef
Post by Yassyeef »
abarthmultijet wrote: 06 Apr 2022, 20:26 No problem, hope you are happy with it.
Try to plug in your phone, this code supports apple carplay/ android auto. If it doesn't work i know how to activate it. Send me a PM!
I get problem on my abarth 16v 1.4 multijet and i have change the kilometer but its not succes to alignment proxy and in customise i have this code : 33 32 31 35 30 30 30 31 38 38 30 4F 55 54 50 55 54 2D 4A 49 54 20 08 12 03
4F 84 00 04 10 00 00 00 09 00 00 04 10 00 00 00 80 CO 75 06 FE 00 17 20 AA
80 00 06 00 01 00 94 06 01 01 00 00 00 00 00 7A 41 0A 0C OD 00 00 00 05 00
00 00 00 31 02 51 00 00 00 00
The body say problem with my u connect 7  i have changed and the error code is on the ETM
Can you help me thanks
Yassyeef
Post by Yassyeef »
I have changed on my abarth 500 1.4 multijet , the autoradio to the Uconnect 7  it’s working good i can only listen music and add phone register
Sorry for my English
I have also change the dashboard , and i get the 4th version on dashboard but aftee it changed,
I get problem i have ajust my kilometers so its flashing and i can’t align the proxy good i have problem with the ETM .
My diagnosis is ; 4F 84 00 04 10 00 00 00 4F 84 00 04 10 00 00 00 48 00 00 00 10 00 00 00 0B 00 00 00 10 00
4F 84 00 04 10 00 00 00 09 00 00 04 10 00 00 00 4F 84 00 04 10 00 00 00 09 00 00 04 10 00
Body Computer (BCM /NBC)
Contrôle Moteur (ECM /NCM)
D.A. électrique (EPS/NGE)
Tableau bord (IPC/NQS)
Dispositif de freinage (ABS/BSM/NFR)
Climatiseur (HVAC/NCL)
Noeud Embardée/Accélérat. Latérale (NYL)
Noeud Air Bag (NAB/ORC)
(Multiecuscan 5.1)
Fiat 500 1.4 16V T-Jet/MultiAir
But when i got the alignment proxy and make ctl alt C i get this : 33 32 31 35 30 30 30 31 38 38 30 4F 55 54 50 55 54 2D 4A 49 54 20 08
12 03 4F 84 00 04 10 00 00 00 09 00 00 04 10 00 00 00 80 CO 75 06 FE
00 17 20 AA 80 00 06 00 01 00 94 06 01 01 00 00 00 00 00 7A41 0A 0C
OD 00 00 00 05 00 00 00 00 31 02 51 00 00 00 00
Only 76 bytes
Can someone please help me to fix it
Thanks you very much !!
josesales
Post by josesales »
I replace original radio on my Fiat 500 year 2016 for a 7" Uconnect.
Now I have DTC DAB aereal antena.
When I try align proxy I got error.
Can someone help me with proxy manual configuration to fix this please?
My log:
CAN CONFIGURATION DATA:
4F 80 00 05 00 00 00 00 4F 80 00 05 10 00 00 00 09 00 00 01 10 00 00 00 01 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 80 00 05 00 00 00 00 09 00 00 04 00 00 00 00 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 09 00 00 04 00 00 00 00
33 32 31 35 30 30 31 38 33 30 37 4F 55 54 50 55 54 44 4A 49 54 20 16 04 06 4F 80 00 05 00 00 00 00 09 00 00 04 00 00 00 00 01 C2 73 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 00 94 00 22 00 04 88 00 00 20 80 00 00 40 00 01 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Side Acceleration / Yaw Node (NYL)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
(Multiecuscan 4.7R3)
07-11-2023 11:17:17
Side Acceleration / Yaw Node (NYL): Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Entertainment Telematic Node (ETM): Added / EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
| Byte 148: 00->1C
FAILED TO EXECUTE
