Hi boys,
I'm into a big trouble !
My mother's punto 188 has the body computer burned, and it's impossible to read the 93lc66 because the file is corrupted !
I have changed it with second hand body and key, and riverginate the iaw59f. The car starts normally but the odometer is blinking because it need can alignment procedure!
My question is: is possibile to make correct alignment with fes 3.4.2 after this work ?
I think that the donor car had more or less option than mine.
Fes can help me ?
I ask this question because I don't have car there because I'm away for studing otherwise I would try without askyng !
Thanks in advanced
Beat regards
P.
Proxy alignment punto 188
Re: Proxy alignment punto 188
Yes, You can use FIAT PUNTO '03 1.2 8V or FIAT PUNTO '03 BIPOWER, it's also possible that each FIAT PUNTO '03 will work.
BAS
BAS
Thanks BAS for your reply and help !
With alignment this isn't a problem if the Body is from another car, but with the same id and serial ?
I can align it normally ?
