recently invested in a registered version of MES so that I had more info on all the bits and bobs in my car and decided to do a proxy align to get the cruise control light working. That worked fine but the climate control failed. I tried to 2nd time and again the climate control failed. I decided on one last attepmt and it was a success. Not sure why it would fail so firstly does anyone know what causes it to fail?
Also even after the 100% successful align MES is telling me that some modules need EOL Programming (what ever that is?). Is there any way of finding out what these modules require and is there anyway of sorting it out? Ill post up the last 3 logs as they're the relevant ones.
Thanks in advance!
EOL Programming/Climate control failing Stilo
alex199020
alex199020
Re: EOL Programming/Climate control failing Stilo
CAN CONFIGURATION DATA:
01 02 15 4F 01 02 15 4F 00 00 00 43 00 00 00 02 00 00 00 00
01 02 15 4F 01 00 04 09 01 02 15 4F 01 00 04 09 01 00 04 09
30 34 31 39 32 30 30 31 39 31 33 54 45 52 4D 3A 30 39 20 20 20 20 01 12 07 4F 15 02 01 09 04 00 01 D1 05 00 00 00 84 22 00 00 0A 5C 06 00 00 00 00 00 00 00 13 58 51
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Brake System Node (NFR)
Driver Door Node (NPG)
Climate Control Node (NCL)
Steering Angle Sensor Node (NAS)
Passenger Door Node (NPP)
Parking Sensor Node (NSP)
CURRENTLY AVAILABLE CAN MODULES:
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
24/02/2014 20:08:03
CONNECTED TO:
Fiat Stilo 1.9 JTD
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Brake System Node (NFR):
Driver Door Node (NPG):
Climate Control Node (NCL):
Steering Angle Sensor Node (NAS):
Passenger Door Node (NPP):
Parking Sensor Node (NSP):
CURRENTLY AVAILABLE CAN MODULES::
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (NQS) SUCCESS!
Writing to module: Climate Control Node (NCL) FAILED! - Unknown error
Writing to module: Parking Sensor Node (NSP) SUCCESS!
FAILED TO EXECUTE
24/02/2014 20:10:06
CONNECTED TO:
Fiat Stilo 1.9 JTD
Writing to module: Climate Control Node (NCL) SUCCESS!
COMPLETED
24/02/2014 20:08:03
CONNECTED TO:
Fiat Stilo 1.9 JTD
FAILED TO EXECUTE
24/02/2014 20:10:06
CONNECTED TO:
Fiat Stilo 1.9 JTD
COMPLETED
alex199020
24/02/2014 20:12:06
CONNECTED TO:
Fiat Stilo 1.9 JTD
24/02/2014 20:12:06
CONNECTED TO:
Fiat Stilo 1.9 JTD
Hi,alex199020 wrote:Hi,
Thanks in advance!
I do not know did you find answer on this forum regarding your potential problem for message: "FAILED! - Unknown error" during PROXY...
Solution is very simple: it is the "bug". MES have it for some time and no one should be in panic because of that.
The worst problem is that people when they done the PROXY and when they got the error message they think now that unit is not working.
Solution is very simple, after PROXY has been done, turn off key, wait 1 minute, turn on key and see is everything working. If everything working, then job is well done. No need for additional checking in PROXY list. Maximum you can do see errors in that specific ECU, and if you see them, delete them and that is all.
Hello, I have a stylus with dual-zone climate aftermarket but not connected to the body when I try to align the proxy does not go ahead and error. In the menu of the instrument cluster now I only have 3 items ....
Multiecuscan registrato
Multiecuscan Mobile 1.0.1 su Samsung Omnia i900
