can't setup com port
tony811976
Hi, and I hope you can help me, I have purchased the vag kk lead and coloured leads to read my fiat panda.
I installed the com port drivers from the disk supplied and inserted the vag-com cable in the USB, the computer installed the drivers but it is listed as a kk vag-com lead not a USB com port, what did I do wrong,?
I previously tried a windows 7 laptop, installed the com port drivers first time but it kept saying I didn't have permission to use the port when I tried to connect to the car, so this is why I tried windows 8 but have had less luck
tony811976
Re: can't setup com port
Anyone,? I hoped this was a busy forum.
Hello Tony
Try it again with this driver.
Because often the drivers on the enclosed CD are very old.
And you should Multiecuscan run as administrator.
right mouse button / Administrator
tony811976
Thanks I'll give the admin bit a go today, I'll try those drivers but I think the wife tried those ones,
I'm so dissapointed with it being so hard for me to setup I hope I get it going
tony811976
Hi, those drivers were tried and we installed the .net framework too, it still is recognised as a vag.com km line cable in device manager
. How do I tell the laptop I want it recognised as a usb com,port?
tony811976
I really need some help I still can't install the vag.com USB cable as a USB serial port, windows keeps installing it as a k line vag. Com cable.
It's the same with whatever name your Windows KKL interface will recognize?
The main thing it is recognized
You've installed the driver and set the comport in Multiecuscan.
Then, a reading should work
I am having the same problem. I have installed the latest drivers, plugged in the usb lead and it installs in other devices as VAG KKL 409.1 with a caution saying 'The drivers for this device are not installed. (Code 28)'. Does anyone know why it is not showing up in PORTS (COM & LPT) ?
I am running Win 8.1 with Net framework 3.5.
Thank you
Thank you
Are you using the drivers from the manufacturer of the interface? Which one?kernowgaz wrote:Hi,
Thank you
I first used the drivers that came on a disk with the lead. I then tried using the latest drivers from the FTDI website. I also use a program called FTClean which uninstalls all FTDI drivers and then tried again. Still no joy.
