PURPLE ADAPTER # 4
Re: PURPLE ADAPTER # 4
Hi Eddy
Just out of curiosity (and desire to learn, of course), which the Fiat system uses the L line (pin 15)?
Hi Walter
not that I know of
In older VW, the pin 15 is still needed
not that I know of
Ho Ho Ho ............ BUT VWs do not use the FIAT 3-pin adapter, right?Alfaeddy wrote:Hi Walter
OK![]()
not that I know of
In older VW, the pin 15 is still needed![]()
Waltomatic wrote:Ho Ho Ho ............ BUT VWs do not use the FIAT 3-pin adapter, right?Alfaeddy wrote:Hi Walter
OK![]()
not that I know of
Right !!
Hi Waltomatic,
The hood Module is the ecu for the electric Capote/Soft Roof.
I am still wandering if any Spider owner can check if they can connect on 16 Pin port.
Also, if you have the 3 pin in the battery compartment.
Thanks guy,
Cheers
Thanks guy,
Cheers
Tank You!
Yani solved the problem with new version 2.2.
I am interested in that topic. I have an Alfa Romeo spider of 2003, and same problem than you trying to access electric hood diag. It works for all other diag but not for the hood with purple adaptor!! And I am using MES 2.3.... did you try with 2.3?
thanks,
gilou
thanks,
gilou
Most Spiders use a 3-pin adapter for the electric hood. See heregilou wrote:Hi,
thanks,
gilou
viewtopic.php?f=3&t=4281
I don't have this cable, but it should not as per the supported vehicle list:
Alfa Romeo
Spider '03
2.0 JTS
Bosch Motronic MED7.11 EOBD Injection |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMOBDKey
Bosch ABS 5.3 ASR |INFO|DTC|PRM|ACT| KL 1OBDKey 1 A1
TRW MY97 Airbag (2F-2P) |INFO|DTC|PRM| KL 3OBDKey 3 A2
TRW MY97 Airbag (2F-2P-I) |INFO|DTC|PRM| KL 3OBDKey 3 A2
Harrison climate control |INFO|DTC|PRM|ACT|ADJ| KL 9ELM 9OBDKey 9 A1
Electric Hood Control DURA |INFO|DTC|PRM|ACT| KL 13OBDKey 13 A4
Alfa Romeo
Spider '03
2.0 JTS
