I tried it with older version but same result. Another try, and i got message: " Failed to execute, Security access failed "
"Undefined error" while programming remote on new Bravo
I get this message right after entering security code. Latest registered version (2.7) of Multiecuscan. Everything else works fine. Any ideas?
Re: "Undefined error" while programming remote on new Bravo
Strange...
Same problem.
Mes 2.5 registered.
Mes 2.5 registered.
Same problem, MES 3.3 registered. Is there a solution for that?
i have the same problem, error shows instantly after entering the security code
Bravo 2009 - MES 3.3 registered version - elm327 usb cable
I know this is an old post, but just wondered if there was a solution to this problem, as had the same error while attempting to programm remote on brava '09' , using 3.7 with cantie interface.
No solutions so far... I tried to program the remote also with car key specialist but he did not succeed. I even bought a new key and tried to program it at official Fiat dealer, but no. There is probably something wrong with the car ECU etc...
