Convergence Telematic Module (Blue&Me) Removal
burtaverde
Re: Convergence Telematic Module (Blue&Me) Removal
Post by burtaverde »
Hi. I'm used to AlphaObd but first time on Multiecuscan. I have an android headunit so blue and me on the fiat 500 is useless, and they sometimes talk at the same time so trying to disable it.
I can find byte 38, but in my case its original value is 03 instead of 42. Also if i try to change it to 02 and press "execute" the next time i open it'll be back at 03. It's as if it didn't do anything.
Did i do something wrong?
chrener
Post by chrener »
Convergence telematic module is configured on byte 30 and also 38... Value for CTM is 02...
So if you unplugged it from car your value on byte 30 ond 30 decrease of 02 point... If you have also TPMS right?
So with CTM and TPMS is value 03 on bytes 30 and 38 and without CTM is 01... Value 42 is Wrong...
Understand?
burtaverde
ah yes that makes sense. I didn't unplug it since i don't want to dig through the body so i was hoping to simply disable.
I do have TPMS (its accuracy not being the topic at hand). So then both byte 30 AND byte 38 should be the same, now modified to 01 to disable it?
Do i have to "execute" after changing those values?
Changing the values seems easy, but getting them to stick, less so. Also the odometer is flashing now.
Flynello
Post by Flynello »
Kind regards everyone,
I recently bought a 2013 Fiat Panda 312 4x4 1.3 Multijet, I had the odometer flashing due to the damaged Blu & Me control unit, with the Proxi alignment the alignment failed. On scan I had error B10AA-4A and U1733-87.
I replaced the control unit with the same one, but when I went to do the Proxi alignment I had Convergence Node: Removed. By doing the Proxi alignment the convergence node is removed, the odometer no longer flashes but I have lost all the functions of the Blu & Me.
Please, can someone tell me the Bytes to correct in Custom Proxi, my current Proxi is the following:
Lettura dati configurazione CAN...
CAN CONFIGURATION DATA:
6F 04 00 15 00 00 00 00 6F 04 00 15 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 04 00 15 00 00 00 00 09 04 00 05 00 00 00 00 6F 04 00 15 00 00 00 00 09 04 00 05 00 00 00 00 09 04 00 05 00 00 00 00
30 36 33 31 39 30 30 32 30 36 31 4F 55 54 50 55 54 44 4A 49 54 20 12 09 04 6F 04 00 15 00 00 00 00 09 04 00 05 00 00 00 00 83 C0 71 07 44 01 00 71 AA 10 00 06 00 07 00 8C 06 0B 02 46 00 80 01 01 35 50 0A 1C 0D 00 00 00 17 00 00 00 00 41 04 40 00 80 00 00 00 6D 20 02 04 00 00 00
Body Computer (BCM/NBC)
Controllo motore (ECM/NCM)
Guida Elettrica (EPS/NGE)
Quadro Strumenti (IPC/NQS)
Radio Ricevitore (NRR)
Impianto frenante (ABS/BSM/NFR)
Climatizzatore (HVAC/NCL)
Nodo Sensore Parcheggio (PAM/NSP)
Nodo Air Bag (NAB/ORC)
Coupling Control Node (CCM)
(Multiecuscan 4.8)
22/12/2023 14:39:18
Fiat Panda 2012 1.3 Multijet 16V
Body Computer (BCM/NBC): EOL Ok
Controllo motore (ECM/NCM): Ok
Guida Elettrica (EPS/NGE): Ok
Quadro Strumenti (IPC/NQS): EOL Ok
Radio Ricevitore (NRR): Ok
Impianto frenante (ABS/BSM/NFR): Ok
Climatizzatore (HVAC/NCL): EOL Ok
Nodo Sensore Parcheggio (PAM/NSP): EOL Ok
Nodo Air Bag (NAB/ORC): EOL Ok
Coupling Control Node (CCM): Ok
ATTENZIONE: Questo veicolo è già configurato correttamente. Allineamento PROXI non necessario!
GRAZIE!!!
shpuncik
Post by shpuncik »
Flynello wrote: 22 Dec 2023, 18:42 Kind regards everyone,
(Multiecuscan 4.8)
22/12/2023 14:39:18
GRAZIE!!!
either you have blown fuse or your new B&M module is faulty too. after you connected it, in proxi list it's status should be as "added".
couple posts above there are instructions what to change but doubt it gonna help in your case.
BBOinsam
Post by BBOinsam »
i incorrectly stated in a previous post that i was not seeing this error. as i have been following along with the replies, and the commands in question have come out, i see that running mythfilldatbase does not show the error message. if i run:
Code:
kevinnatan
Post by kevinnatan »
JDalfa wrote: 30 Jun 2021, 16:17 It worked perfectly, thank you!
Is there a list of the custom proxy digits, wat they do/mean?
Boa noite, estou com o mesmo problema né um bravo 1.8 2014, não consigo alinhar o proxy, aparece esse erro, consegue me ajudar ?
05 00 0C 6F 05 00 0C 6F 04 00 0C 05 00 00 04 01 00 00 00 00
05 00 0C 6F 04 00 04 89 05 00 0C 6F 04 00 04 89 04 00 04 09
33 33 31 39 38 30 30 30 36 30 30 4F 55 54 50 55 54 2D 4A 49 54 20 11 04 25 6F 0C 00 05 89 04 00 04 85 01 00 07 BC 48 5F 07 00 02 80 06 01 0F 29 28 00 81 04 11 00 B4 00 00 08 00 00 00 00 00 06 00 05 0C 01 00 00 00 3A 20 A8 88 00
Controle Motor (ECM/NCM)
Direção Elétrica (EPS/NGE)
Quadro de instrumentos (IPC/NQS)
Rádio Receptor/Rádio navegador de mapas (NRR/RMN)
Sistema dos freios (ABS/BSM/NFR)
Nó Info-Telemático/Convergence (NIT/NCV)
Climatizador de ar (HVAC/NCL)
Câmbio Automático (TCM/NCA/NCR)
Nó Sensor Estacionamento (PAM/NSP)
Nó Air Bag (NAB/ORC)
(Multiecuscan 4.8)
16/11/2024 10:19:56
Fiat Bravo '07 1.4 16V
Controle Motor (ECM/NCM): Ok
Direção Elétrica (EPS/NGE): Ok
Quadro de instrumentos (IPC/NQS): EOL Ok
Rádio Receptor/Rádio navegador de mapas (NRR/RMN): Ok
Sistema dos freios (ABS/BSM/NFR): Ok
Nó Info-Telemático/Convergence (NIT/NCV): -
Climatizador de ar (HVAC/NCL): EOL Ok
Câmbio Automático (TCM/NCA/NCR): Ok
Nó Sensor Estacionamento (PAM/NSP): Ok
Nó Air Bag (NAB/ORC): EOL Ok
EXECUTING ADJUSTMENT...
PROCEDIMENTO ALINHAMENTO PROXI
Writing to module: Body Computer (BCM/NBC) SUCCESS!
Writing to module: Quadro de instrumentos (IPC/NQS) SUCCESS!
Writing to module: Nó Info-Telemático/Convergence (NIT/NCV) FAILED! - Timeout error
Writing to module: Climatizador de ar (HVAC/NCL) SUCCESS!
Writing to module: Nó Air Bag (NAB/ORC) SUCCESS!
FALHOU A EXECUÇÃO
Kind Regards joost
