Can anyone help me with the following:
I have here a Fiat Tipo 1.4 without cruise control. I bought a new steering wheel with cruise control buttons and do als a bcm swap from L0 to L1.
So everything, including the cruise control, works fine. The only thing is that i got a daylight error. The LEDs are not working and in the instrument panel is a light error. Apply it with MES and proxy does not make any difference.
However, when i swap the bcm L0 back in place, DRL is working fine.
No DRL anymore on Fiat Tipo after retrofit Cruise control
Re: No DRL anymore on Fiat Tipo after retrofit Cruise control
Because of your new BCM is from different body type as original... For example BCM from hatchback type is not changeable into sedan and oposit...
Look into Config, see if it can be activated
