My fiat 500c has suffered battery drain, after quick research found its blue and me that causing it so disconnected it. Bought the MES software to do the proxy alignment however I cant connect to body computer unit... Every single time. I can scan vehicle, clear errors, look into different things but proxy alignment is not possible. What is strange, upon scanning the car I found that the BCM is Delphi 595 which is normally in fiat 500 1.4 turbo and abarth! So I tried to do the proxy from that tab in MES but still no joy! Milage is flashing, blue and me is disconnected, 130gbp for the tool down the drain... I am using vlinker fs with yellow a3 cable provided by the uk distributor gendan, running it on windows 11.. maybe someone has experienced something like this before and solved it?
this is what i see on the scan, bear in mind my car is 2014 fiat 500 convertible 0.9 twinair
