Upgrading Uconnect 5'' radio unit for an android one : proxy alignement necessary ?
balou86
Post by balou86 »
Hello :)
Wondering if anyone had done a similar operation,
On my 2019 Fiat Doblo 263 1.3 Multijet, I'm planning to replace the basic radio unit (Ucconnect 5'') , with an android multimedia unit.
Reading the specs , I understand it should be delivered with a CAN-BUS adapter wich seems to be the RP5-FT-002 from SimpleSoft.
I'm wondering if I will need to do a proxy alignment procedure (basic ? custom ?) ?
My understanding is I should not need to , as the canbus adapter should emulate some sort of "pre-aligned" unit .
I did a similar replacement recently on my old opel corsa , and didnt need to tinker anything.
Thanks for any feedback :)
balou86
Re: Upgrading Uconnect 5'' radio unit for an android one : proxy alignement necessary ?
Post by balou86 »
Feedback after installation of the Android headunit : no need for a proxy alignement.
Although there's a "U1725-87 - Entertainment Telematic Module" missing message present in the Body Computer ECU, the CAN Setup reports no need for an alignment (EOL Ok at the ETM line in CAN Setup) and everything is working fine.
abarthmultijet
Post by abarthmultijet »
No flashing milage?
balou86
Post by balou86 »
abarthmultijet wrote: 30 Mar 2026, 20:08 No flashing milage?
Nope
balou86
Post by balou86 »
I remember now seeing your comment in the Aliexpress store, almost made me not buy it ... what is your car model ?
It seems your car doesn't recognise the CANBUS module.
Did you update it to the latest firmware ? (you can do CAN update via OTA in settings)
Also I'm almost certain this module is powered by a 2-pin connector you need to plug in, make sure it is as you can easily miss it (almost did, mine was kind of hidden in the harness).
