I’m sorry if this question has been answered before, I have searched the forum but I haven’t find the answer.
I have Marea 1.9 TD 100 year 1997 and by Supported Vehicles list best interface to use is KKL?
Where I can find explanation how to connect to 3 wire connector on engine side ECU?
Only explanation I can find is how to modify connector to connect to ABS, AIRBAG.
tnx in advance…
marea TD100 year 1997 3 wire connection
mareadizlo
Re: marea TD100 year 1997 3 wire connection
The easy way is to puchase a 3 pin to EOBD connection lead.
If you Google the subject then you should find some useful links.
A point to note is that the Fiat 3Pin diagnostic connector does NOT have a 12V supply. This is why the 3-pin adapters come with an extra wire to connect to 12V.
Elm & I think KKL require a vehicle 12V supply to work.
mareadizlo
Ok , tnx now I understand.
On ebay :
http://cgi.ebay.com/ebaymotors/Adapter- ... veQ5fTools
Best regards.
On ebay :
Best regards.
