I am trying to reset the aribag light on the dash.
Since I've tried this many times using different systems (uniscan 1.83, tsdiag, alfadiag) and failed I thought i'd give multiecuscan a try!
Now then, due to my playing about with uniscan 1.83, I have 2 socketcom serial cards. These work great in DOS and Windows and there are no driver issues.
I have seen lots of of configuration info for the FTDI chip based cables but none for serial. What setting should I use? I cannot decrease the buffer size and I cannot connect at 10400bps...is this an issue?
In the past I've successfully connected Uniscan on my laptop (i must be one of the few in the UK that managed it!) with the engine ECU. However I get no response from either airbag or bosch ECU in multiecuscan.
Is there a way to see a more "verbose" connection screen?
