Hello.
I was wondering what cables and adapter to use to reset my fob. I have the following cables:
[img]http://imageshack.com/a/img836/5738/5n7m.jpg
http://imageshack.com/a/img838/171/euzg.jpg[/img]
I tried to modify OBD2 cable but I am getting no where with this. Stuffs look way to much complicated and it is mainly because the information is shattered all over the place.
stilo key fob
Re: stilo key fob
@ stilofiat
If you want to reprogram remote control - opening and closing doors with remote control, than you need ELM 327 cable.
You have that cable. It is the cable on your first photo and it is called "OBD 2 Scanner".
Description on how to programme remote control you have on first page. I also put some photos s you can not miss nothing...
Re: stilo key fob
Ís it possible to reprogram the key using the elm327 via bluetooth or its needed the elm327 cable version?
Re: stilo key fob
Hello all.
I was just wondering will i be able to reset fob using VAGKKL + Fiatecusan cable or does it have to be ELM 327? These terms r so confusing. Id be really helpful if there is any where to read and understand what they mean like KKL, ELM etc etc. and difference between these cables.
