excuse me, I tried it with a vag-com cable not changed but I could not connect!
Can you tell me if I have to change the cable and how? thanks
SEICENTO SPI 899
Re: SEICENTO SPI 899
hello.
Write exactly what you're doing, how you connect on which pin you have set up an interface? if you have the power to 3 pin adapter?
Write a step by step. Can you do something wrong, or have a broken/damage cable?
startrek punto I downloaded and I installed it on pc.
I connected my cable vag-com and I set the correct com port in software.
I logged on to my fiat 600 (903 cc) through the 'adapter to 3 pin but can not connect to the ECU.
my cable is not 'changed so I wanted to know if there is to do some change and how.
Thanks for the reply
Start engine!
turn off all other com ports!
You may try the http://sourceforge.net/projects/iaw-scan/files/ but notice that it requires a cheap and simple to build, yet dedicated interface.
Well tzok
. I downloaded the file and what's next? how to turn - start?
if I need to download all files from 001 to 0017?
You must download the BIN! http://sourceforge.net/projects/iaw-sca ... in/0.0.17/
this ist a .exe !
Work this with KKL and 3PIN Fiat Adapter? I dont have a SPI Seicento/Cinquecento
this ist a .exe !
No, currently it requires a dedicated interface with separate lines towards and from ECU, but soon you may expect introduction of VAG-COM interface support.
Everything required to build a current interface can be found in pcb.zip file:
http://sourceforge.net/projects/iaw-sca ... p/download
Thank you, tzok''(Thomas) for the program and help and technical advice to the IAW ECU SCAN.
I tested today, 2 hours - to say that the program has a much more powerful than startrek. Graphs, the more the actual engine operating parameters, delete the error, component testers, etc.
Thanks for the modifications so that the program works with the interface VAG KKL .
I recommend all of the IAW in accordance with the specifications of the program
