Multiecuscan Full package.
Re: Multiecuscan Full package.
The error code is shown on the Errors Tab at top of the display.
The error code is also recorded in the run log in the program directory.
Timmy
Post by Timmy »
Am i correct in saying that MES can reprogramme a replacement ABS control module,
secondhand or new.
Tim
If by reprogram you mean replace your existing one with another of the same type then yes. This will require a Proxi Alignment.
If by reprogram you mean change the coding inside the ABS unit then the answer is no.
Timmy
Post by Timmy »
I meant replace the existing one with a replacement second hand one.
Thankyou for the help.
tim
Timmy
Post by Timmy »
How can I get the Numeric code of any faults. Thanks. Tim
Timmy wrote:How can I get the Numeric code of any faults. Thanks. Tim
See viewtopic.php?f=5&t=5884#p19454
Timmy
Post by Timmy »
Here are the listed OBD codes specific to ABS systems. The numeric code gives specific information to
the possible problem.
http://www.troublecodes.net/ccodes/
I,d like to know if Multiecuscan gives the numeric values in a file somewhere.
I know it lists the error in a written method, but the numeric value is what I,m looking for. Thanks
Tim
MES keeps CONNECTION logs in its directory.
These log show all error codes, parameter requests and responses.
This is what I mentioned and pointed at earlier.
Look in the MES Program directory for these files.
Timmy
Post by Timmy »
What file would it list C1111
Thankyou
Timmy
Post by Timmy »
Here is a perfect screen shot of the type of format I,m looking for,
https://www.google.ie/search?q=multiecu ... EceA16z60M:
The image has the numeric code on the left hand column, text code next, and then the information about the fault.
And when highlited the lower window information gives helpful direction in curing the fault.
I cant get this type of layout at all. Why.
Tim
