aam583
Post by aam583 »
DragonTek77 wrote: 31 Aug 2025, 06:45 Update: I managed to find the backup file in the MES program. I didn't know MES saved every proxy you do in a text file. I got all the lights to disappear. The only thing I still don't have is the TPMS screen that shows all the pressures; that is still missing but everything else works fine
Could you please share what your current proxy is? I am stuck without the boost gauge...
budgoz
Post by budgoz »
aam583 wrote: 02 Oct 2025, 00:40
For the Sport gauge to work properly you need to change byte 49 to C0.
If your 2017 cluster comes from an EU car, there will always be some errors because it's not fully compatible.
If you need help make the Abarth graphics work post your proxy.
Romain
Post by Romain »
Hello everyone,
I have a 2020 Abarth with Uconnect 7, but I can't connect to CarPlay.
I have the following factory settings:
33 32 31 35 30 30 36 30 37 30 34 4F 55 54 50 55 54 44 4A 49 54 20 20 09 23 4F 04 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C7 75 06 F9 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 02 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 88 00 00 20 80 00 00 40 00 85 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 23 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I modified the bytes
Bytes 121 = 40 (No changing) Navi
Bytes 148 = 05 (At place of 44)
Bytes 157 = 01 (At place of 00 ) Carplay
Bytes 158 = 00 (No changing)
Bytes 159 = 00 (No changing)
Bytes 160 = 01 (At place of 00 ) Android Auto
33 32 31 35 30 30 36 30 37 30 34 4F 55 54 50 55 54 44 4A 49 54 20 20 09 23 4F 04 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C7 75 06 F9 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 02 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 88 00 00 20 80 00 00 40 00 85 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 23 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
But unfortunately, it doesn't work.
The coding is flashed correctly, but CarPlay doesn't work even with the original Apple cable.
Can someone help me?
GTEX
Post by GTEX »
Hello everyone, I have a 2019 Fiat 500 Lounge with Uconnect 7" and a single USB port. I have tried all the proxy codes I could find to activate Carplay without success. I reverse engineered the bytes but couldn't get it to work.
My configuration from the Engineering menu:
Serial OTF191083901276, SW Version 23.00.81.03, HW Version D6, Checksum (CRC), 7d8e
Hardware release 0.32.5.1, Firmware release 0.0.0.2, Serial number OTF191083901276, Production Date 2019-03-24
HWariant DAB eMMC GPS S&S USB BT LS CAN MIC1 dMIC 9V PhtSupl DT, FP
USB : 0x30001:Hub [2 Ports], 0x30102:Unknown Device, 0x30101:Mass Storage
My proxy stock :
33 32 31 35 30 30 34 36 36 37 39 4F 55 54 50 55 54 44 4A 49 54 20 18 12 17 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 C7 71 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 82 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 00 94 00 22 00 04 88 00 00 20 80 00 00 44 00 D5 00 0F 00 00 00 00 01 00 60 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
193 bytes with uconnect on 44 and USB byte 115 on 00. I changed it to 05 01 01 and USB to 04, but without success. When I connect my phone, I have mobile phone display options that appear with iPhone, but when I click on them, nothing happens.
Excel Drive link for byte comparison: https://1drv.ms/x/c/cc9bc4f3da1db915/EQPHSG6-iuNHgD_NkPnBWOYBOd-eZimcQdsRJ4DVtrAU8Q?e=tuZUZ9
Does anyone have any ideas or could share their proxy code for a Fiat 500 or Abarth with a single USB port?
@Romain did you find a solution ? we have the same uconnect byte 44 and I did not see a lot this byte.
budgoz
Post by budgoz »
GTEX wrote: 16 Nov 2025, 13:28 Hello everyone, I have a 2019 Fiat 500 Lounge with Uconnect 7" and a single USB port. I have tried all the proxy codes I could find to activate Carplay without success. I reverse engineered the bytes but couldn't get it to work.
My proxy stock :
unfortunately not all Uconnects 7" have the hardware for the Carplay.
Anyway your best shot is to update the firmware first (link: https://drive.google.com/file/d/1Y4irT-r9_FgREHnCzB6YPCEZ3VQtspgH/view?usp=sharing).
You need to extract all the fies in the root folder of a USB drive formatted in FAT32. After you insert it and wait for 60 seconds, the Uconnect will prompt you to start the update. It takes approx 30 minutes, you better do it while driving or with the battery connected to a charger. DO NOT TURN THE DASH/UCONNECT OFF DURING THE PROCESS.
After the upadte is done, you can try again with the proxy alignment.
You don not have the AUX port, right?
My suggestion is the following version:
33 32 31 35 30 30 34 36 36 37 39 4F 55 54 50 55 54 44 4A 49 54 20 18 12 17 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 C7 75 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 82 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 00 94 00 22 00 04 88 00 00 20 80 00 00 44 00 95 00 0F 00 00 00 00 01 00 C0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Fingers crossed.
GTEX
Post by GTEX »
budgoz wrote: 18 Nov 2025, 13:31
My proxy stock :
Fingers crossed.
Thanks for your reply and your time to help me. Yes, I think I don't have the right hardware for CarPlay, even though the car was built in 2019.
I don't have an aux port; I only have one USB port.
I'm still trying to find a solution and I wondered if CarPlay doesn't work, maybe Android Auto does. I tested it and it works!
I was inspired by this post: https://www.forum-fiat-tipo.net/viewtopic.php?f=22&t=2129&p=25611&hilit=carplay#p25611 (French version).
He uses an Android Auto AI box that can emulate CarPlay with a passthrough Android Auto.
I'm going to buy one and test it to get CarPlay. Maybe other peoples tried this option ? and can be able to use CarPlay on a large screen.
Romain
Post by Romain »
My proxy stock :
After several weeks of research, I was able to confirm that my Uconnect 7 didn't have factory-installed CarPlay, so I bought a Uconnect 7 with CarPlay from this seller on eBay for €300: https://www.ebay.fr/usr/ivbon92
Once received and installed, everything worked perfectly. The only issue was the flashing mileage on the dashboard. I had to perform a new proxy alignment to get everything working correctly.
Here is the current coding in the vehicle:
33 32 31 35 30 30 36 30 37 30 34 4F 55 54 50 55 54 44 4A 49 54 20 20 09 23 4F 04 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C7 75 06 F9 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 02 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 88 00 00 20 80 00 00 44 00 D5 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 23 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
aletremo
Post by aletremo »
budgoz wrote: 31 Aug 2024, 13:31
aletremo wrote: 23 Jul 2024, 14:39 hi, after change my uconnect from 5 to 7, my beats audio system rear speaker and subwoofer stop working.
Now i dont know if it can be a problem whit the proxy alignment or somenthing else.
Could anyone hel me?
Post your proxy and Ill see what I can do.
hello, thank for the response, i will update my proxy soon, did you thinkit could be a proxy error code, or it could be a funzion to re enable in the body computer?
andrewpsmith
Post by andrewpsmith »
HI,
I am hoping somone can help me with a question regarding steering wheel buttons.
I own a fiat 500 pop 2017 (UK). The car came with the most basic head unit (no NAV, Phone), DAB. I recently upgraded it to a uconnect 7 system and following advice on these excellent thread made the suggested changes to enable car play etc. After the proxy alignment the head unit worked fine and the mileage stopped flashing.
The final step for me was to fit a steering wheel from a 2024 Car that included the Voice Activation and Phone Buttons. Having fitted the new steering wheel the buttons function but (i) only in the locations they functioned with original wheel (ii) they perform the task of the previous wheel. So for example, pressing the top phone button changes the SRC, pressing a button where there was a blank previoulsy doesn't do anything.
I am not sure if the new steering wheel needs to be coded or I need to change another piece of hardware.
My original proxy alignment code is:
33 32 31 35 30 30 32 33 33 31 31 4F 55 54 50 55 54 44 4A 49 54 20 16 11 21 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 13 C2 73 06 F4 00 1C B0 00 00 00 26 00 01 00 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 02 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 94 00 21 00 04 88 02 00 10 00 00 00 40 00 81 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
My updated code (193) Bytes that results in a working Uconnect system (carplay, phone, DAB, no NAV) is...
33 32 31 35 30 30 32 33 33 31 31 4F 55 54 50 55 54 44 4A 49 54 20 16 11 21 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 13 C2 73 06 F4 00 1C B0 00 00 00 26 00 01 00 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 02 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 94 00 21 00 04 88 02 00 10 00 00 00 44 00 D5 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
If anyone could offer any advice on what is needed to make the buttons function that would be greatly appreciated.
budgoz
Post by budgoz »
aletremo wrote: 19 Nov 2025, 20:23
If you changed your proxy to make the Uconnect 7 work, it's absolutely possible that you disable the Beats amplifier.
