FioFiat500Abarth
2017 Abarth TFT Cluster swap with Euro version
Post by FioFiat500Abarth »
Hope someone can help
I got a 2017 Fiat Abarth
Swapped the TFT cluster for a Euro version
Ran the proxy alignment codes, everything went through complete no errors except the logo on the cluster refuses to change to anything BUT Abarth.
I can put any other cluster EXCEPT Abarth. Makes no sense at all. Byte 65 as 60 never changes to Abarth logo.
Any thoughts?
Timbo172
Re: 2017 Abarth TFT Cluster swap with Euro version
Post by Timbo172 »
FioFiat500Abarth wrote: 22 May 2024, 18:32 Hope someone can help
Any thoughts?
Try byte 65 as 20 or 30 then byte 81 as 51
FioFiat500Abarth
Timbo172 wrote: 22 May 2024, 23:09
Any thoughts?
I think I tried byte 65 as 20. I will try the others you mentioned. Thank you!
FioFiat500Abarth
Any thoughts?
Changed byte 81 to 51 and it worked. Cluster display now Abarth. But now I get ECO and ABS warning lights on all the time.
Volker_Racho
Post by Volker_Racho »
Englisch
Hello everyone, I have my Abarth 2013 and it has a TFT display from me. Unfortunately I can't change the display language. Is there a trick?
Snegovalex
Post by Snegovalex »
FioFiat500Abarth wrote: 24 May 2024, 22:48
Any thoughts?
Hello! I have the same problem.
My TFT panel does not want to work in 2012 Abarth Mexico made. I changed byte 65 to 60, 40, 30, 20, but the abarth skin did not turn on. after which, I changed byte 81 to 51 and everything worked. but now the ABS error is on all the time, and the sport icon on the boost sensor is on in all modes. is there a solution? please help.
budgoz
Post by budgoz »
Snegovalex wrote: 31 Aug 2024, 13:15
You can try to change byte 81 to 58 or to 31 instead of 51, but the problem is that the TFT you got is for the european model so it's not fully compatible.
If you replaced also the gauge with the new model, try byte 49 to C0.
