NullReferenceException after performing oil service reset
Peter K
Post by Peter K »
Everytime, after performing an oil service reset, everything works fine until the message "turn off the ignition for 60 seconds" appears. After a few seconds, the connection is terminated and the window crashes, returning to the main window in MES. The following error message pops up (apologies, it's in Dutch):
Image (https://ibb.co/219FfG3n)
Detailed:
Image (https://ibb.co/LX0JsC5L)
I believe the oil service reset itself does get exectued succesfully..
Any ideas what might cause this error?
Re: NullReferenceException after performing oil service reset
I'd check for .NET updates.
Peter K
Post by Peter K »
Thanks, already done, no difference...
Can you post the FULL exception information.
You should be able to enlarge the window and select and copy the contents.
Peter K
Post by Peter K »
Well, we've done multiple resets now, same results over and over again.
As the car has done several miles by now, I don't want to reset it again.
So the picture(s) above is the only one for now...couldn't enlarge the window, I'm afraid...
abarthmultijet
Post by abarthmultijet »
I am thinking a software bug. Try to update to the latest version 5.3 instead of 4.6.
