				LED installed: How to switch off the light bulb control on the FIAT 500c Hybrid
				Posted: 02 Jun 2025, 14:25
				by JAM
				Hello, I have installed LED bulbs in the FIAT 500c 1.0 Hybrid (Modell 2020/21, 312) and when I start the car I get a brief warning that the lights need to be checked. I would like to switch this off because it is annoying. I don't want to work with resistors, they get too hot in summer. Is it possible to switch off the “control function” with Multiecuscan (I got the full version with an yellow adapter) somewhere? Thanks for a hint. JAM
				Re: LED installed: How to switch off the light bulb control on the FIAT 500c Hybrid
				Posted: 02 Jun 2025, 18:30
				by chrener
				Hi which bulbs did you swap? Main lights or high beam?
You can turn off the bulbchecking.
Share your proxistring here and I will take a look on it...
regards
				Posted: 04 Jun 2025, 14:53
				by JAM
				I have equipped the low beam, high beam, brake lights and tail lights / parking lights with LEDs. I have not found a function for switching off the light control in Multiecuscan for all available control units / “Proxis”. I have selected FIAT 500 1.0 GSE Hybrid as my vehicle. Although I have approvals from Philips and Osram for the LEDs, I have not installed any resistors as this is not practical.
