No Connection to ECU via K-Line Adapter – Fiat Barchetta
Posted: 10 Jun 2025, 06:38
				Hello everyone,
I'm trying to connect to the Engine ECU on my Fiat Barchetta using a 3-pin adapter connected to a K-Line interface (via USB). I'm using MultiECUScan, which successfully detects the USB interface, but when I try to connect to the ECU, I get no response. FiatEcuScan gives the same results
Just to clarify:
Ignition is ON
Adapter is connected to the 3-pin diagnostic port
Interface is recognized in MultiECUScan
i've installed ftdi drivers, set the port to com5 (seen on some threads), set the latency timer to 1msec.
I've attached some photos that show my actual settings.
Has anyone run into this issue before? Could it be a wiring issue, incorrect adapter, or something else I'm missing?
Thanks in advance for any help or suggestions!
Just to clarify:
Ignition is ON
