500 Pop Proxi Timeout ALL Modules (2014+ ????)
Fiat500_pop
Post by Fiat500_pop »
Hi Yall.
Really need some help...Have a bad Blue & Me module...
Using Vgate/vLinker cable...multiecuscan 5.4
Cannot do a proxi to remove it/resync...All Modules fail with Timeout Error.
BIG issue is that the CAR is a 6-15 build date but scanning the modules they all say "MY12"!!!
What Proxi Alignment do I use??? The normal one or the one that says (2014+)???
(NEITHER are working BTW)
Latency is set to 1...don't know what else to do...
TIA! dc
Fiat500_pop
Re: 500 Pop Proxi Timeout ALL Modules (2014+ ????)
...It was the cable...
Got an EML one and all is good now!
https://www.amazon.com/dp/B07MQ8GHG3?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
Are you saying that the vGate Linker you said you used in your first post did not work?
