Error C1212-55 Fiat Punto
Posted: 23 Mar 2026, 10:52
by Devonpaul
Car in question Fiat Punto 2012 1.4 8v
Having connected Multiecuscan in a failed attempt to stop the odometer flashing I now have the above error code which is “ engine torque signal from injection control unit” . The error did not exist prior to connecting so must have been caused by the B&M failed proxies alignment. The problem seems to have been raised in the last but no successful solution. Does anyone have a solution as the Mot looms large and the abs light is on !!. Cheers folks
Re: Error C1212-55 Fiat Punto
Posted: 23 Mar 2026, 11:19
by Devonpaul
Just something else to add
When I checked in the engine data it was set as 1.3 multi jet (which it isn’t ) so I changed this to what it actually is I.e 1.4 8v
If I change it back will it cause any other issues?
Posted: 25 Mar 2026, 19:46
by abarthmultijet
Devonpaul wrote: 23 Mar 2026, 11:19 Just something else to add
Probably best just to leave that as is.
Posted: 28 Mar 2026, 18:09
by Devonpaul
Having contacted MES direct for advice It was recommended to return the engine type to its original setting although it seems wrong. Having done this and then a Proxi realignment the problem is fixed. Note to future self : don’t just change something because it look wrong!!
