Hey guys!
Got a trouble when was trying to connect to Panda 1.2 EPS, it says "ECU doesn't respond"
I tried also get connection to Engine, Airbag and ABS. Engine is OK. Airbag and ABS got fails.
Then I putted together 1, 3, 7 and 9 pins on the OBD plug.
After that I've got connection to Airbag. But still got nothing for power steering...
Any idea?
FES 2.3.1
VAG KKL 4.09
Port speed is "9600"
Latency is "1"
Thanx,
Alex
Panda 1.2 power steering connection fail
croydonchris
Re: Panda 1.2 power steering connection fail
I have a Panda 1.2 8V but I have to set my ELM327 to 38400 to connect to the ABS as the ABS ECU will not connect at 9600 baud but the engine ECU will.
I hope this is of use to you.
Regards ~ Chris
Regards ~ Chris
Fiatmaniac
What ECU?
IAW?
IAW?
