Hello, i've downloaded new release 2.6.
The test mode in settings (F9) it's ok, but when i select fiat 500, i report error connecting and if i search for ecu (F11), no ecu found.
Another think, my Fiat 500 is mjet and not jtd , is an error of typing or 2.6 don't support fiat 500 1.3 mjt?
Many thanks
Lorenzo
No ECU on fiat 500 1.3 Mjet problem not fixed
gargamella
Re: No ECU on fiat 500 1.3 Mjet
Please send me a report by clicking at the red "Send Reeport" button which appears after you disconnect (or fail to connect) from the ECU.
gargamella
I've sent to you, but it says in anounimous form, check you've received.
But for fiat 500 jtd you mean mtj? is an error of word?
Many thanks
Lorenzo
Many thanks
Lorenzo
Sorry, but I will need one more report to research into this issue.
I need you to do the following:
1. Scan your vehicle
2. Try to connect to engine or power steering.
3. Send report
Thanks.
3. Send report
Thanks.
gargamella
Hi Yani, i've re-sent you the report, tell me if is arrived.
The message that i receive from the software is Ecu connection failed, and something about wrong pin.
Could you please answer me about if the fiat 500mjet is named fiat 500 jtd in your software?
I'm talking about the "new fiat 500" year 2008
many thanks Yani
many thanks Yani
Please try version 2.6.1. It should fix this problem.
gargamella
Re: No ECU on fiat 500 1.3 Mjet problem not fixed
Hello Yani, i've tryed to connect.
In "engine management" (the first, when i connect, it enter in the ecu, i see immediately the message of "restrition for unregistered version" and immediately remind me back to the first screen when i open the multiecuscan software, and i can't do anything in this parameters. But unregistered version can do something in "engine"?
In "body" and "service" when i try to connect, i obtain the same errors of before, error to connect ecu and wrong pin.
I've sented you 2 report
Many thanks
Lorenzo
Many thanks
Lorenzo
I too have the same problem.
Using bluetooth ELM327 the test works fine giving it all ok but when I do Connect does not connect and even research ECU.
Fiat 5001.3Mjet 2008
Pardon my English but I'm using a translator
Nl software is also possible to reset the service more than an oil change?
Last bumped by gargamella on 12 Dec 2010, 23:48.
