Hallo.
I have a vag com 912 direct usb interface that works fine with vcds (Volkswagen)I have installed ecuscan but it cant connect to the ecu in my ducato 2003.The popup tells that the portsettings are wrong.Howewer i dont manage to change this ,the settings dialog box only shows com-ports.Are there any solutions ?Thanks for answear in advance.
vag com direct usb interface
adão carlos vieira
Re: vag com direct usb interface
Friend, I am user multiecuscan, works very well with VAG-COM 409, KKL, with ELM 327 1.3 but does not work with vag-com 912,
OK ,that is what i suspected.Surching e-bay for a cheep vag 409,1
it is very cheap! Maximum 10 USD!northwin wrote:OK ,that is what i suspected.Surching e-bay for a cheep vag 409,1
