Just want to inform you that there is a bug in FES v.2.7.2!
As the title of topic says FES does not save first report.
As you already know reports are saved in "C:\Program Files\Multiecuscan" folder after disconnecting FES from the car. All those reports are saved as "Notepad" file or Text Document file (".txt") as someone is calling them.
All other connections, second, third, fourth… are just fine but always is missing the first one.
I tested on few Alfas and there is same problem… I hope you can fix it…
