ecu scan download from internet
as you can download ecu scan for my stilo multiwagon 1.6 and i have only 20 minutes to read the faults can i do this with the download from the internet and and as im using a laptop can i get a usb connection that fits the laptop and code reader connection in my stilo multiwagon 1.6 and if you can will this delete the codes as my managment light comes on and garage charges me a fortune to read and delete .
Re: ecu scan download from internet
- just download the FES software;
- install FES software on your laptop (or PC)
- install all the drivers
- open FES software
- connect your interface to the car (stilo 1.6) and to the laptop (or PC)
- click connect button on the FES software
and then you have 20 minutes to see all parameters
and if you want to delete errors you gonna have just enough time
when your 20 minutes expire, you just close the FES software and start again in 1 or 5 or 20 secondes later and then again you have 20 minutes to work...
and again 20 min. and again 20 min. and again 20 minutes...it is easy...
- open FES software
