hello.
is it possible to get the cruise control activation option for the 159 in fiat ecu scan?
thanks in advance.
cheers
Alfa 159 Cruise Control activation - proxy alignement
Re: Alfa 159 Cruise Control activation - proxy alignement
It is already there.
true, but in my short flash look i didn't see it. searched for it on one of my friends brera.
anything on the superclosure part for the 159?
Yani,
Is it possible to add option for cruise control activation for ALFA 147 1.6 TS 16V 105/120CV?
I was looking everywhere but I could not found it!
Unfortunately, the CC activation is not available for 147.
If your ECU is the ME7.3.1 (it must be, I believe 147 had it for all TS), it already has cruise control activated.alfa156sarajevo wrote:Yani,
You only need to do the wiring loom from cruise lever to ecu.
I done that on my 156, which is the same.
Cheers!
update: did the activation on the brera aswell but from the 159 menu.
