register
pues
register
Post by pues »
I want to format the pc and wanted to know how I have to do to get the serial back to the program
a greeting
Re: register
On bottom left of Multiecuscan main panel click the Blue Register area just above the F9 Settings.
This will give you a dialog box with your Hardware Key and License Key.
Make an accurate note of both of these values.
As your are only formatting your hard drive than I doubt your Hardware Key will change and you can use the date to reinstall the program.
You can also hit the Deactivate button and generate a removal key. Make a note of this.
I don't think you will need the removal key but if you do then this key will help you reinstall after the format.
pues
Re: register
Post by pues »
hello!
format the PC and I gave him to the button to deactivate and aimed at all the information that I come up
now since do I have to do to activate it again?
thanks.
Re: register
Sorry but I am having difficulty in understanding your English.
Write again in your OWN language and I'll get google to translate from your language to English
pues
Re: register
Post by pues »
Hace unos días formatee el pc y use el botón desactívate.
Ahora quería saber como tengo que hacer para activar de nuevo el programa
Un saludo
Above post edited to S130 to read:
A few days ago I formatted the pc and uses the desactivate button (I assume our friend used deactivate before the format).
Now I wanted to know how what I have to do to reactivate the program
greetings
Re: register
The deactviate process will have given you a Removal Key.
You use this Removal Key to obtain a new License Key and activate the program.
If this fails then send an Email to support@multieecuscan.net with your original hardware and license keys with any purchase details you have.
El proceso deactviate le habrá dado una llave de eliminación.
Se utiliza esta clave de eliminación para obtener una nueva clave de licencia y activar el programa.
Si esto falla, entonces envíe un correo electrónico a support@multieecuscan.net con el hardware original y las claves de licencia con los detalles de compra que tiene.
pues
Re: register
Post by pues »
No se como utilizar la llave de eliminación.
Re: register
Please send me an email with the new Hardware Key at support@multiecuscan.net and I will resolve the problem.
Yani says
Por favor envíeme un correo electrónico con la llave de hardware nuevo en support@multiecuscan.net y voy a resolver el problema.
