Hello Yani,
please support for 166 ME 2.1,ME3.1 ECU, Xenon Adjustment and Automatic Gear.
thx
Frank
						ME 2.1,ME3.1,Xenon Adjustment and Automatic Gear 166
Re: ME 2.1,ME3.1,Xenon Adjustment and Automatic Gear 166
What you mean by xenon adjustment? Is this possible by ECU?
I adjusted manualy in my Alfa 166 - you have to use hex (6mm?) key and turn screw on top of electric motor - it's huge regulation this way!
for Xenon is adjusted via the diagnostic plug, there was no bolt on the motor.
frank
						frank
Hmmm. If You talking about bixenons it may be correct. Xenon before FL has manual regulation by this bolt: http://img689.imageshack.us/img689/6144/xenon2xi.jpg
Yes, but Xenon is adjusted via the diagnostic plug and the Fiat Examiner.
Frank
						Frank
The ME 2.1 is the same as the ME 7.3.1 but without the two Lambda sensors in the exhaust branches (Bank1 & Bank2)
All the other sensors & Actuators are the same. Pre 03 156 2.5V6 (ME 2.1) & post 03 156 2.5V6(ME7.3.1)
The same diagnostic can be used.
Does that effectively mean I could pick any of the cars listed that use the 7.3.1 ECU to communicate with my 2.1 ECU?devc wrote:The ME 2.1 is the same as the ME 7.3.1 but without the two Lambda sensors in the exhaust branches (Bank1 & Bank2)
Yes, that'll work. I used the GTA ECU, you'll only get a warning about the ISO code.156V6 wrote:Does that effectively mean I could pick any of the cars listed that use the 7.3.1 ECU to communicate with my 2.1 ECU?devc wrote:The ME 2.1 is the same as the ME 7.3.1 but without the two Lambda sensors in the exhaust branches (Bank1 & Bank2)
But i would also like to see specific support for the ME 2.1 ECU.
