Hi does anybidy know if above is same as 2002 model or have they mowed to CAN bus system in 2005 ?
Thanks for your replay !
						Alfa 156 2,0 JTS 2005
Re: Alfa 156 2,0 JTS 2005
It is the same as 2002. You can connect to the engine with k-line (VAGCOM cable) on pin 7.
The engine management ECU is Bosch Motronic MeD7.11.
ME7.3.1
Please advise what ECU is used in 2.0JTS. I can not choose ECU version if I choose 2.0JTS in the program?!
And must say - great software!!!
Yes Nice software noticed livedata parameters is a bit unstable else all other works great,
