Hí people ,
My ELM 327 is 1.3a , but between pins  6 and 14 the resistance is 40 OHMs , some problem with this ?
Which is the resistance good for CAN protocol ?
Thanks.
						about ELM327 help
Re: about ELM327 help
viewtopic.php?f=5&t=1493jony wrote:Hí people ,
Thanks.
How about you?
If a resistance of 40 ohms installed between 6 + 14?
or have you measured this resistance?
greeting
						How about you?
greeting
Hí mate,
I measured the resistance with a multimeter between pin 6 and 14 of ELM327.
People say it must have, around 100 Ohms , this is a good interface .
I do not know where you got this information?
The resistance must be very high between Pin 6 +14
so that no signal is connected between the high and low.
I knew the values and have not measured my ELM
The resistance between pins 6 + 14 >47 kOhm
no 40 or 100 ohms
The ELM 1.3a should have no problems in the CAN bus.
Be removed at this ELM has nothing to solder or
no 40 or 100 ohms
