calibrating Alfa 156 selespeed gearbox
alfahal
Post by alfahal »
Hi, sorry if this is a daft question, but does the engine need to be running during the process, me changing gears, driving the car etc. ...or should it be off? When the engine is off (key to MAR) the test finishes in 1 second. It's supposed to take 5 min... what am I missing?
I also tried bleeding the clutch before doing this (as per instructions) and it says: "Clutch Actuator OK" and "Clutch Position Sensor OK" in the instructions... what does this mean? Is this a confirmation that these are ok before performing the bleed? Or does it mean that I'm supposed to click OK on something... in which case I was never presented with a dialog during the process... It did take approximately 20 sec though... so I just assumed it's all ok. But if I'm missing something... please chime in, thanks!!
It's an Alfa 156 Selespeed 2.0TS y2000
Cheers/ Henrik
Darlo
Re: calibrating Alfa 156 selespeed gearbox
Post by Darlo »
I am having same problem, did you sort yours out ?
