today i have tried to perform a proxy alignment using Multiecusan version 1.9
This is the result:
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Body Computer Node (NBC) FAILED! - Timeout error
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
Writing to module: Airbag Node (NAB) FAILED! - Timeout error
FAILED TO EXECUTE
My ELM 327 1.4 interface is pass the self test properly and is the new model with producer fix for resistor.
During F11/F12 scan i got 2 errors:
Controllo Motore
UNKNOWN/UNSUPPORTED
ISO Code: 7A 07 C7 8C 29
ABS
UNKNOWN/UNSUPPORTED
ISO Code: EC 07 9B 0B 6E
Any suggestion?
Regards
Roberto
Mito 1.4 51KW(70cv) 8v MY2014 Proxy Error
netchainer
Re: Mito 1.4 51KW(70cv) 8v MY2014 Proxy Error
Ok, it seems that Fiat has made some small changes to the PROXI in new vihicles. We will include support for this in next release.
Hello, I'm having trouble using the software on my fiat stilo 1.8 8v manufactured in Brazil. Making a brief consultation found that the injection system is Delphi MT27E, so whenever I plug in my car and do the scan it shows a message of motor unknown or unsupported for the same gearbox. My car has the Selespeed gearbox (Dualogic called in Brazil). Do you have any plans to support this injection?yani wrote:Ok, it seems that Fiat has made some small changes to the PROXI in new vihicles. We will include support for this in next release.
Regards.
