High air flow rate
High air flow rate
Hello! Air quantity (This is the amount of air taken in by the engine.) idling shows - 320 kg per hour. This is normal or a bug or malfunction of the vehicle? Thanks! Vechicle Fiat Bravo T-jet 120 /2008 year
Re: High air flow rate
Completely wrong!
Make sure the unit of measurement is the same.
How much should be showing on such vehicle?
+- 10 kg/h
Does this air quantity refer to Fiat Bravo t-jet 120, and is it indicated in multiecuscan program?
Do you mean indications 320 +-10 kg/h?
NOOO!!! My Marea 2.4 gasoline: [9.10~11.90] kg/h idle
Multiecuscan reads but does not have the manufacturer limits for each model. I know the my car, but there is a general logic parameters.
I understand, thank you. A week later, I will be able to see values on the same car as me.
Which year is your Marea? 2002?Waltomatic wrote:NOOO!!! My Marea 2.4 gasoline: [9.10~11.90] kg/h idle
