Hi, got the KKL leads and have configured everything (I believe) but get the connection failed message. check connections and ports etc, so frustrating.
Punto 03 1.2 8v
Airbag warning light
I've checked some of the old threads on here, just can't connect.
Thanks in advance for ANY suggestions to end my frustrations on this matter.
Can't connect to ecu
puntomadness
Re: Can't connect to ecu
Sorry for late answer...
I do not know which version of MES you are using but on older version was a problem with reading airbag ECU. Did you try to connect to some other module (engine or abs)?
