Netbook connection problem
I'm trying connect to ECU from netbook Asus eee pc 1005ha (atom n280, 1GB Ram).
Com port settings are OK, but I Can't connect to ECU.
I tried .NET 2.0 and .NET 3.5 ... and nothing.
Is this possible to using ebook to scan ECU?
Marek
AR 159 1.9 JTD
						AR 159 1.9 JTD
Re: Netbook connection problem
I think your notebook should work...
Just one questions, did you install FTDI drivers?
I did.
I tested this circuit by connecting pin 24 to 25 of FT232BL ( External loop Rx-Tx).
Com port works good with Terminal application but doesn't work with ECU scanner
Marek
AR 159 1.9 JTD
						AR 159 1.9 JTD
I heard about problem with Asus EEE allready. Try another notebook.
Hi,hanzs wrote:I heard about problem with Asus EEE allready. Try another notebook.
Don't blame it on the EEE.
The problem is not in the netbook. I use EEEPC 900HA for testing and it works flawlessly with Multiecuscan.
yani: I heard from another user, that he tried Asus EEE with Stilo and no connection, then tried big notebook and it worked fine.
I have no another netbook / notebook.
Some people has a problem with using a netbook to connect to ECU
Let's try to find solution
I think my hardware works good. COM port on usb transmits and receives data.
Maybe Atom processor is the problem in this case?
I turned off any needless applications, but still can't connect to ECU
Marek
AR 159 1.9 JTD
						AR 159 1.9 JTD
I use an acer one net book with no problem
John
						John
I thing it should work... One more question did you setup your COM port settings on your laptop?markos7 wrote:I think my hardware works good. COM port on usb transmits and receives data.
I mean: "Control Panel>System>Hardware>Device Manager>Port Settings..."
of course i did.
I tried different com port settings including settings suggested by yani
Marek
AR 159 1.9 JTD
						AR 159 1.9 JTD
