Alfa TS - Mass air flow (throttle closed) ?
enkei
Post by enkei »
I would be grateful if anyone can clarify which parts/sensors these values come from on a 2006 (CF3) Alfa 2.0 TS 147?
1. "Mass air flow (throttle closed)"
2. "Air quantity"
The reason I ask is that I suspect my MAF sensor is failing. At engine revs from idle up to 3100 rpm, "Mass air flow (throttle closed)" ranges from only 3.5-3.7 kg/h. I'm wondering if those are normal values or if they do indeed indicate a failing MAF sensor.
Also, what is "air quantity"?
Thanks in advance!
Nick
