Suddenly MES stops logging after a couple of seconds
Posted: 19 Mar 2020, 18:59
I'm using MES to debug my non starting 156 2.4 jtdm.
I wanted to check some signals (EGR signal, FUel pressure and obviously RPM)
When idle the monitor is fine.
When I try to start, after 2 seconds the log stops totally (my RPM is still at 250 rpm). I know the voltage of my battery is severely dropping of course, but may this explain the cut ?
I also tried to start and to MES with a running car battery aside, the cut still occurs very early in the start process, unable to graph or monitor any value
(and the car is not starting of course
I rebooted my machine and everything was fine with MES until now, no change in cable or settings.
Thanks !!
Thanks !!
