Salve!io ho un problema con il multiecuscan.
Quando lo collego all auto(una 500 restyling tutta originale) e vado nella pagina can setup,il nodo ETM mi compare in rosso con dicitura NUOVO/EOL OK.
Se faccio l allineamento proxy poi i km iniziano a lampeggiare.
Per sistemare il tutto ho dovuto andare in officina fiat,i quali mi hanno fatto il ripristino del proxy originale.
Effettivamente,paragonando il proxy originale con quello che mi mostra il multiecuscan,cambiano due byte.
Il byte 30 e il byte 38 in origine sono impostati a 10,ma il multiecuscan me li imposta a 02.
Perché questo???qualcosa non va nel multiecuscan,é un bug???
Problema allineamento proxy fiat 500 restyling
Re: Problema allineamento proxy fiat 500 restyling
Confermo,é un problema legato alla versione 4.6 dove hanno aggiunto il can setup per le 500 dotate di UCONNECT.
Caricato oggi la vecchia versione 4.5 e tutto funziona regolarmente.
In this case you simply have to run the regular “CAN Setup / PROXI Alignment Procedure” (not the one for Uconnect). We added this special “Uconnect” PROXI procedure because there are many models of Uconnect devices in Fiat 500 that have software bug and do not work with regular PROXI alignment. It seems that the Uconnect in your car is not one of these units and you simply have to run the regular procedure.
Ok, but the menu of the multiecuscan had to be clearer. Because anyway, simply doing the proxy alignment, it changes two bytes. This is because it reads the proxy incorrectly. In fact if I connect the multiecuscan and I go to look at the proxy (ctrl + alt + c), these two bytes are displayed wrong.Fortunately I work in the fiat workshop and I managed to solve by resetting the car configuration via wi-tech .... and only in this way did the km stop flashing. Checking then the two proxies I saw that multiecuscan changed the two bytes for no reason. I tried also on the other two 500 that I had in the salon and on both the multiecuscan changed the two bytes in the proxy. I'm sorry, but in my opinion this I consider it a fairly important bug.
Solo 500 oppure anche 500X ? Ho una 500x MY2019 1.0 turbo 120CV e a breve dovrei fare l'allineamento per lo Uconnect 7" e sensori di parcheggio OEM. Non vorrei trovarmi nei casini.
A proposito, poiché questo modello non è incluso nel MES ultima versione, sapete quale body usare ?
Penso solo 500 3 porte,non la X.
Per verificare,basta che lo colleghi all auto e verifichi che non segni nessuna centralina con la dicitura "NUOVO/EOL NOT OK".
Grazie per l'info. Ad ogni modo ho fatto una prova senza bypassare la SWG e utilizzando la 1.4 16V T-jet e sembra che sia tutto ok.
justmekeiley
I just purchased your obdlink and disk for fiat 500 lounge 2011 ,I put a new cluster into my car and i have installed everything and everything has connected fine, we did the PROXI alignment and everything went well except the MPH on the cluster has now changed to KILOMETERS, i watched a youtube video that had the same problem and they said they had to get a HEX DECIMAL CODE to fix it. PLEASE HELP
@yani
@yani
