Convergence Telematic Module (Blue&Me) Removal
DaveDevil
Post by DaveDevil »
I think my Blue&Me module broke. I can't connect to it, and my odometer is flashing.
I don't use that module, because I already removed the RadioNav module 2 years ago, and I deactivated from the proxy the radio module by changing byte 38 from 42 to 02 (suggested by an user here)
I saw online that the B&M module costs more than 150 euros. I don't want to spend so much money only for being able to realign the proxi!
Does anyone know the correct byte to edit for module removal?
Thanks to anyone responding!
P.S. The car is a Giulietta 2011 1.4
Re: Convergence Telematic Module (Blue&Me) Removal
check in CAN Setup screen if B&M module is shown as removed. if yes, perform proxi - should remove it and odo will stop flashing.
nelly19780
Post by nelly19780 »
Follow this tutorial. I used this to remove the Blue&Me module on a Punto and worked perfectly.
https://www.youtube.com/watch?v=RD__7upfeaw
DaveDevil
Post by DaveDevil »
shpuncik wrote: 31 May 2021, 09:26 check in CAN Setup screen if B&M module is shown as removed. if yes, perform proxi - should remove it and odo will stop flashing.
I removed it, and it showed as removed, but the proxi align failed.
Apparently, before attempting alignment the module must be removed with the battery disconnected!
DaveDevil
Post by DaveDevil »
nelly19780 wrote: 02 Jun 2021, 10:42 Hello,
Really thanks, I was missing the part while the module should be removed with no battery connected! Thanks!!!
JDalfa
Post by JDalfa »
Thanks for this video, if i remove the oem radionav as wel (flip up display type) wich parameters do i need to change to stop the odo from blinking?
DaveDevil
Post by DaveDevil »
I have been told to change manually byte 38 from value 42 to 02.
It worked for me
JDalfa
Post by JDalfa »
Also in the proxy settings menu? And then perform proxy alignment?
Thank you!
DaveDevil
Post by DaveDevil »
You have to manually edit the proxy value. I don't remember where to do it, I'm on vacation right now and I don't have my laptop with me
JDalfa
Post by JDalfa »
Ok maybe you can let me know when you’re back home.
Or if anyone else can help please let me know!
Thanks!
