I can not connect to eps
tonight I bought the program fiat ECU scanner registered but failed to diagnose the eps of 19 fiat punto jtd 2002. I wish to state that I'm using cable elm 327 2.1 very good reason working on the engine com port settings are 38400 4-bit s panel Fiat ECU Control Program. jumper pin 7 pin 9 was done on 327 Elm someone can help me? I'd be really grate
						Re: I can not connect to eps
HI,
Unfortunately, the problem is most probably in your ELM interface.
The fact that you can connect to the engine means that you have used correct settings/drivers/etc., however, the fact that you cannot conect to the EPS means that your ELM interface cannot connect to the CAN network.
The ELM software inside is either v1.2, or the interface is faulty.
Yani, grazie per avermi permesso di rispondere. domani mi sento l'olmo 327 03.01 poi vi farò sapere! perché quello che ho sentito stanotte e la versione 1.2. una domanda? eps ma non comunica con il pin 9 collegato al pin 7 del olmo. Impossibile comunicare con la rete che si aspettano di sentire da voi .. sistema.eps Andrea.
Yani, thanks for letting me respond. tomorrow I feel the elm 327 03.01 then I'll let you know! because what I felt tonight and version 1.2. a question? eps but not communicating with pin 9 connected to pin 7 of the elm. Can not communicate with the network that expect to hear from you .. sistema.eps andrea.
The Punto EPS is on the CAN network. You don't need to bridge any pins for it. A standard ELM 327 v1.3 without any modifications can connect it.
hello! I solved the problem. I changed the cable, now usually use cable elm 327 1.3 pe are really happy to make the diagnosis eps to my point.
