Fiat coupe unable to access bosch 5.3 ABS
Gino
Post by Gino »
Hi, I'm unable to stay connected to fiat coupe bosch 5.3 abs ecu. It flashes up for a split second
UNSUPPORTED /unknown software press Y to continue and before I can do anything it kicked me out.
Also when I try scan for ecu I get
Scanning.
ABS
UNKNOWN/UNSUPPORTED ISO Code: 6B 02 25 08 EF
COMPLETED
Any ideas?
Re: Fiat coupe unable to access bosch 5.3 ABS
try checking adapter settings, timing in device manager and high latency mode in MES
Gino
Post by Gino »
All latency and timings set to what's suggested in the guidelines. I might add I have no issues connecting to engine ecu.
MES supports four different versions of the Coupe by year and Engine sizes. Also different interfaces and adapters. Check you have the correct interface and adapter. Also what does the initial Scan show for fitted / recognised ECUs?
See: https://www.multiecuscan.net/SupportedVehiclesList.aspx
Gino
Post by Gino »
Hi, thanks for your reply. From the table it seems I have the correct cable and adapter. When I try to connect I get a screen flash up for about a second and it give an iso number.. In the model and software? Boxes you get something like #%?! /*"_#. Then says press Y to continue but then instantly kicks me out to the home screen..
When I do an initial scan for the abs ecu it says...
ABS
COMPLETED
Ratty
Post by Ratty »
Are you sure its 5.3 and not 2si version?
Gino
Post by Gino »
Well, should be 5.3 as all coupe 20vt... I take it 2si is not supported by MES??
BBOinsam
Post by BBOinsam »
Your HWID PCIVEN_105A&DEV_5275 is currently supported it seems. But under XP. Are you building with XP source?
Look under WorkbenchCommonDPsMassStorageScriptFilesxp for the file FASTTRAK.SY_. Expand it and see what version it is and whether it is what you expected.
Regards,
Galapo.
