The ISO code is a unique identifier of each type of ECU.
Unfortunately, your ECU is not supported by Multiecuscan yet.
You can select the ECU from Bravo 1.4 and connect to your car but the parameter values will not be correct.
The error codes, however, should be correct (but this is only for the error number, the descriptions could be incorrect).
Fiat Uno 1.0ie assembled in poland 2000, Bosch MA1.7
Re: Fiat Uno 1.0ie assembled in poland 2000, Bosch MA1.7
Hi all,
I have a '94 Tipo 1.6ie Monomotronic 1.7 and as your Uno, the ISO code is not recognized but I was able to view the DTC, but not the parameters (unfortunately)
viewtopic.php?f=5&t=3278&p=10261&hilit=Tipo#p10261
This ECU is already included in next release of Multiecuscan.
ultraszatanfire
That's nice to know! When do you plan to release that updated version?
