Hi to everyone!
I'm not able to have the xenon lights (Valeo) calibrated with multiecuscan. Is there anyone who is able to do it?
Is there a bug in the program?
Thank you.
Alfa 147 - xenon calibration
Alfa 147 1.9 JTD 16V 150CV Distinctive
VAG KKL 409.1 ELM327 v1.4a
Re: Alfa 147 - xenon calibration
The program says that the calibration failed.
Which interface did you used to calibrate xenon lights (KKL or ELM)?
Hi. I used the ELM. I can see all the parameters but when I go to calibration it is written that there is no calibration and the sensors are out of range. When I try to calibrate it says that I cannot do it..
No one?
Do you have any errors in the control module?
Also, did you check the MIN/MAX calibration position and the actual position of the front/rear sensors?
The only thing I can tell you is that calibration is not possible.
I can use everything else with multiecuscan. Everything else is working.
How do I check the MIN/MAX calibration position and the actual position of the sensors?
Thank you.
Thank you.
The same problem on my 159. Not possible to do the calibration.
Who knows why....
Yani?
Yani?
Anyone?
I still have the problem. It would be nice if someone could explain me how to solve the problem.
