I have a 159 3.2 JTS ti 2008 - is it possible to reset any of the parameters in the ECU module - particularly the following:
- Overrev count
- Max. Engine speed time
- Maximum RPM operation
Or any of the parameters in the engine module.
can you reset the overev count parameters?
Re: can you reset the overev count parameters?
You can only do "reset of motor self-adaptive parameters".
"This function allows to set to zero all the motor self-adaptive parameters. WARNING: after zeroing the self-adaptive parameters remember to carry out the climate control learn procedure (key on MAR with climate control on for 1 minute)."
Beside that you can read/ delete errors, see parameters and do some actuators tests...
Easiest way foe you is to install MES and click on simulate button.
There you can find all information what MES can do...
