I recently bought and downloaded the latest version of Multiecuscan and I have bought a VAG KKL 409.1 16 pin cable as well as a 16 pin to 3 pin adapter cable in order to connect to my Alfa 145 2.0 16V plastic top.
I know both my cables work as I've read the ECU codes off my Alfa GTV 3.0 V6 and I've tested my 16 pin to 3 pin cable on an electrical tester so I know that works. When I try to connect to my 145, I go to option and click test and it comes up with an error message saying that no interface was found.
MES and my ECU don't seem to be connecting to each other. I have tried to connect to my ABS system and I get no connection either?
I'm running a new laptop with Windows 7.
Any help will be appreciated guys
cheers
GTV sean
