So this is my problem:
Car: Fiat Coupe 1.8 16v 1998
Interface: http://www.ebay.de/itm/Interface-Adapte ... OC:DE:3160
- 3 pin cable connected / + to accumulator connected / key is ON
- starting multiecuscan / scanning Result:
Engine Hitachi MPI injection ISO Code: 45 85 83 94 B6
- Test interface Connection:
Testing latency 200 bytes of data
Min latency:1
Max latency:1
acceptable tolerance ~5ms
System supports high resolution timer
Testing timer with 1000ms ---> result 1014ms
Testing timer with 250ms ---> result 251ms
Testing timer with 750ms ---> result 752ms
Testing timer with 100ms ---> result 101ms
Now when i try to connect ----> ECU no Response
Com settings: I tryed different...Read some guides and other toppics...Tryed all options i found but still no connection. On some settings the differences between the pings are a bit different like 1000ms ---> 1013 but still the same problem.
Drivers: from the cd i got with the cables.
Looks like i am doing something wrong here. I hope you can help me out
Greetings
MBF
