Multiecuscan 2.0 - WORK IN PROGRESS!!!
Re: Multiecuscan 2.0 - WORK IN PROGRESS!!!
I`m hoping for:
- Fixed DPF regeneration function for 159 2.4 JTDm
- Service interval reset for Alfa 159
Yani can you tell me above functions will be in version 2.0?
Great work, yani.
I have a question. Will there be a support for ABS 5.3 (Bosch) in Lancia Kappa 2.4 JTD (2000)?
				AstonDBS510
Hi!
I'm new to the forum so sorry if I'm posting in the wrong topic. I want to know will this new version have support for
Fiat Bravo 1.9 8v Multijet and if not are you planning to develop it ?
I believe it has Bosch-EDC 16C39, please correct me if I'm wrong
Thank you in advance
BTW, I hope there will be polish version.
Nice work Yani.
I hope new version will support service reset too
because i'm going to use it for steering wheels error reset on a punto mk2 and service reset on new fiat panda.
i have a question for elm327 support.
I didn't understand if software will do everything just with an elm interface? or i need to modify some pins as actual vag-com cable?
because i already have a elm327 1.3a device but it's a bluetooth one, so eventually i can't open it for modding.
thank you.
bye bye
thank you.
bye bye
Y just wanted to congratulate you on your work Yani.Your helping a lot of us out here.
If you want Y could help you with translating from english to romanian or hungarian.
By the way may Y ask how work goes with the 2.0 version of this very good softwear?!
Congrates. and just keep up the good work...
Frici from Transylvania (Romania)
You are the best !Great work
Does it support Bosch Motronic M2,7?
Now March is gone, how far are you???, support for Fiat Grande Punto 1.3 diesel 75hk multijet (2007)?
I just tried the cable anyway and now airbag failure
So now i have 3 errors ABS, AIRBAG and ENGINE lamps on.... fffff
Please give us an update..... then i would be very
Best regards
Peder
Best regards
Peder
Please be patient! I'm working very hard to release v2.0.
As far as I know Fiat Grande Punto (2007) is CAN-only. You cannot do anything with VagCom cable. You'll need ELM 327.
However, it will not be supported in v2.0. I'll add support for Grande Punto soon.
